Helt nya.bild finns längre ner.
Pris 200 kr st
180 mm i diameter med 30mm hål i lager
Nypris 823 kr (1650 för båda alltså!!)
http://www.merafritid.se/f800-12-lin.../3604-264.aspx
Kan skickas eller avhämtas i Hällefors
Ska tydligen passa skotrarna nedan:
2007 JAGUAR Z1 1100 EFI - REAR SUSPENSION REAR ARM ASSEMBLY
2008 F570 - REAR SUSPENSION REAR ARM ASSEMBLY
2008 T570 - REAR SUSPENSION REAR ARM ASSEMBLY
2008 JAGUAR Z1 1100 EFI SNO PRO - REAR SUSPENSION REAR ARM ASSEMBLY
2008 F8 EFI SNO PRO - REAR SUSPENSION REAR ARM ASSEMBLY
2008 F1000 EFI SNO PRO - REAR SUSPENSION REAR ARM ASSEMBLY
2008 F8 EFI - REAR SUSPENSION REAR ARM ASSEMBLY
2008 F6 EFI LXR - REAR SUSPENSION REAR ARM ASSEMBLY
2008 F5 EFI - REAR SUSPENSION REAR ARM ASSEMBLY
2008 TZ1 TOURING LXR - REAR SUSPENSION REAR ARM ASSEMBLY
2008 T500 - REAR SUSPENSION REAR ARM ASSEMBLY
2008 JAGUAR Z1 1100 EFI - REAR SUSPENSION REAR ARM ASSEMBLY
2008 F1000 EFI SNO PRO LXR - REAR SUSPENSION REAR ARM ASSEMBLY
2008 F6 EFI SNO PRO - REAR SUSPENSION REAR ARM ASSEMBLY
2008 F1000 EFI LXR - REAR SUSPENSION REAR ARM ASSEMBLY
2008 F6 EFI - REAR SUSPENSION REAR ARM ASSEMBLY
2008 TZ1 TOURING - REAR SUSPENSION REAR ARM ASSEMBLY
2008 JAGUAR Z1 1100 EFI SNO PRO LIMITED EDITION - REAR SUSPENSION REAR ARM ASSEMBLY SNO PRO NIGHTFIRE LIMITED EDITION
2008 F8 EFI SNO PRO LIMITED EDITION - REAR SUSPENSION REAR ARM ASSEMBLY SNO PRO NIGHTFIRE LIMITED EDITION
2008 F1000 EFI SNO PRO LIMITED EDITION - REAR SUSPENSION REAR ARM ASSEMBLY SNO PRO NIGHTFIRE LIMITED EDITION
2008 F8 EFI LXR - REAR SUSPENSION REAR ARM ASSEMBLY
2008 F1000 EFI - REAR SUSPENSION REAR ARM ASSEMBLY
2008 F5 EFI LXR - REAR SUSPENSION REAR ARM ASSEMBLY
2009 Z1 TURBO LXR - REAR SUSPENSION REAR ARM ASSEMBLY
2009 F8 EFI LXR LE - REAR SUSPENSION REAR ARM ASSEMBLY
2009 Z1 TURBO SNO PRO - REAR SUSPENSION REAR ARM ASSEMBLY
2009 F5 EFI - REAR SUSPENSION REAR ARM ASSEMBLY
2009 F6 SNO PRO - REAR SUSPENSION REAR ARM ASSEMBLY
2009 TZ1 PARK - REAR SUSPENSION REAR ARM ASSEMBLY
2009 BEARCAT 570 - REAR SUSPENSION REAR ARM ASSEMBLY
2009 T570 TOURING - REAR SUSPENSION REAR ARM ASSEMBLY
2009 Z1 BEARCAT XT - REAR SUSPENSION REAR ARM ASSEMBLY
2009 Z1 TURBO - REAR SUSPENSION REAR ARM ASSEMBLY
2009 F8 EFI LXR - REAR SUSPENSION REAR ARM ASSEMBLY
2009 Z1 1100 EFI - REAR SUSPENSION REAR ARM ASSEMBLY
2009 F1000 SNO PRO - REAR SUSPENSION REAR ARM ASSEMBLY
2009 TZ1 TURBO LXR LE - REAR SUSPENSION REAR ARM ASSEMBLY
2009 TZ1 TOURING LXR - REAR SUSPENSION REAR ARM ASSEMBLY
2009 BEARCAT 570 LONG TRACK - REAR SUSPENSION REAR ARM ASSEMBLY
2009 F570 - REAR SUSPENSION REAR ARM ASSEMBLY
2009 Z1 TURBO LXR LE - REAR SUSPENSION REAR ARM ASSEMBLY
2009 Z1 1100 EFI LXR - REAR SUSPENSION REAR ARM ASSEMBLY
2009 F8 EFI - REAR SUSPENSION REAR ARM ASSEMBLY
2009 F5 EFI LXR - REAR SUSPENSION REAR ARM ASSEMBLY
2009 F8 EFI SNO PRO - REAR SUSPENSION REAR ARM ASSEMBLY
2009 TZ1 TURBO LXR - REAR SUSPENSION REAR ARM ASSEMBLY
2009 TZ1 TOURING - REAR SUSPENSION REAR ARM ASSEMBLY
2009 T500 TOURING - REAR SUSPENSION REAR ARM ASSEMBLY
2009 BEARCAT 570 XT - REAR SUSPENSION REAR ARM ASSEMBLY
2010 Z1 TURBO EXT - REAR SUSPENSION REAR ARM ASSEMBLY
2010 TZ1 TOURING - REAR SUSPENSION REAR ARM ASSEMBLY
2010 T570 TOURING - REAR SUSPENSION REAR ARM ASSEMBLY
2010 BEARCAT Z1 XT - REAR SUSPENSION REAR ARM ASSEMBLY
2010 TZ1 TURBO LXR LE - REAR SUSPENSION REAR ARM ASSEMBLY
2010 TZ1 TURBO LXR - REAR SUSPENSION REAR ARM ASSEMBLY
2010 BEARCAT 570 - REAR SUSPENSION REAR ARM ASSEMBLY
2010 BEARCAT 570 XT - REAR SUSPENSION REAR ARM ASSEMBLY
2010 Z1 TURBO EXT SNO PRO - REAR SUSPENSION REAR ARM ASSEMBLY
2010 TZ1 TOURING LXR - REAR SUSPENSION REAR ARM ASSEMBLY
2010 BEARCAT 570 LONG TRACK - REAR SUSPENSION REAR ARM ASSEMBLY
2011 TZ1 TURBO LXR LTD - REAR SUSPENSION REAR ARM ASSEMBLY
2011 F8 EXT - REAR SUSPENSION REAR ARM ASSEMBLY
2011 T570 TOURING - REAR SUSPENSION REAR ARM ASSEMBLY
2011 BEARCAT Z1 XT - REAR SUSPENSION REAR ARM ASSEMBLY
2011 TZ1 LXR LTD - REAR SUSPENSION REAR ARM ASSEMBLY
2011 F8 EXT SNO PRO - REAR SUSPENSION REAR ARM ASSEMBLY
2011 BEARCAT 570 LTD - REAR SUSPENSION REAR ARM ASSEMBLY
2011 BEARCAT Z1 XT LTD - REAR SUSPENSION REAR ARM ASSEMBLY
2011 TZ1 TOURING - REAR SUSPENSION REAR ARM ASSEMBLY
2011 Z1 TURBO EXT - REAR SUSPENSION REAR ARM ASSEMBLY
2011 BEARCAT 570 - REAR SUSPENSION REAR ARM ASSEMBLY
2011 BEARCAT 570 XT - REAR SUSPENSION REAR ARM ASSEMBLY
2012 BEARCAT 570 - REAR SUSPENSION REAR ARM ASSEMBLY
2012 TZ1 - REAR SUSPENSION REAR ARM ASSEMBLY
2012 SNO PRO 600 CROSS COUNTRY - REAR SUSPENSION REAR ARM ASSEMBLY
2012 F 800 SNO PRO LTD - REAR SUSPENSION REAR ARM ASSEMBLY
2012 BEARCAT 570 XT - REAR SUSPENSION REAR ARM ASSEMBLY
2012 F 1100 LXR - REAR SUSPENSION REAR ARM ASSEMBLY
2012 F 1100 TURBO SNO PRO - REAR SUSPENSION REAR ARM ASSEMBLY
2012 F 1100 SNO PRO - REAR SUSPENSION REAR ARM ASSEMBLY
2012 TZ1 TURBO LXR LTD - REAR SUSPENSION REAR ARM ASSEMBLY
2012 SNO PRO 600 - REAR SUSPENSION REAR ARM ASSEMBLY
2012 F 1100 SNO PRO LTD - REAR SUSPENSION REAR ARM ASSEMBLY
2012 BEARCAT Z1 XT LTD - REAR SUSPENSION REAR ARM ASSEMBLY
2012 F 800 LXR - REAR SUSPENSION REAR ARM ASSEMBLY
2012 F 800 SNO PRO ANNIVERSARY - REAR SUSPENSION REAR ARM ASSEMBLY
2012 F 800 SNO PRO - REAR SUSPENSION REAR ARM ASSEMBLY
2012 T570 - REAR SUSPENSION REAR ARM ASSEMBLY
2012 TZ1 LXR - REAR SUSPENSION REAR ARM ASSEMBLY
2012 BEARCAT Z1 XT GS - REAR SUSPENSION REAR ARM ASSEMBLY
2012 F 1100 TURBO SNO PRO LTD - REAR SUSPENSION REAR ARM ASSEMBLY
2012 F 1100 TURBO LXR - REAR SUSPENSION REAR ARM ASSEMBLY
2012 BEARCAT Z1 XT - REAR SUSPENSION REAR ARM ASSEMBLY
2012 F 1100 TURBO SNO PRO ANNIVERSARY - REAR SUSPENSION REAR ARM ASSEMBLY
2012 F 1100 SNO PRO ANNIVERSARY - REAR SUSPENSION REAR ARM ASSEMBLY
2013 F 800 LXR - REAR SUSPENSION REAR ARM ASSEMBLY
2013 TZ1 - REAR SUSPENSION REAR ARM ASSEMBLY
2013 F 800 SNO PRO RR - REAR SUSPENSION REAR ARM ASSEMBLY
2013 F 800 SNO PRO - REAR SUSPENSION REAR ARM ASSEMBLY
2013 F 1100 SNO PRO LTD - REAR SUSPENSION REAR ARM ASSEMBLY
2013 BEARCAT Z1 XT LTD - REAR SUSPENSION REAR ARM ASSEMBLY
2013 T570 - REAR SUSPENSION REAR ARM ASSEMBLY
2013 TZ1 TURBO LXR - REAR SUSPENSION REAR ARM ASSEMBLY
2013 F 800 TUCKER HIBBERT SIGNATURE EDITION - REAR SUSPENSION REAR ARM ASSEMBLY
2013 F 800 SNO PRO LTD - REAR SUSPENSION REAR ARM ASSEMBLY
2013 F 1100 TURBO SNO PRO LTD - REAR SUSPENSION REAR ARM ASSEMBLY
2013 F 1100 SNO PRO - REAR SUSPENSION REAR ARM ASSEMBLY
2013 BEARCAT Z1 XT GS - REAR SUSPENSION REAR ARM ASSEMBLY
2013 BEARCAT Z1 XT - REAR SUSPENSION REAR ARM ASSEMBLY
2013 TZ1 LXR - REAR SUSPENSION REAR ARM ASSEMBLY
2013 F 1100 TURBO SNO PRO RR - REAR SUSPENSION REAR ARM ASSEMBLY
2013 F 1100 TURBO LXR - REAR SUSPENSION REAR ARM ASSEMBLY
2013 F 1100 TURBO SNO PRO - REAR SUSPENSION REAR ARM ASSEMBLY
2013 F 1100 LXR - REAR SUSPENSION REAR ARM ASSEMBLY
2013 BEARCAT 570 XT - REAR SUSPENSION REAR ARM ASSEMBLY
2013 BEARCAT 570 - REAR SUSPENSION REAR ARM ASSEMBLY
Pris 200 kr st
