Summit 800X 08
ilves
7 nov 2006
764
det finns en forumtråd om detta i en annan svensk skotertidning där det diskuteras om "problemet" och diverse åtgärder från BRP samt vanliga "svenssons".
j-son
18 jul 2006
1.157
Varför inte diskutera i det här forumet då? eller förstod jag dig helt fel?
iaf. Har du inte fått ut din nya rem än? Alla återförsäljare har fått nya remmar, men just nu går det bara att ordna 1 rem/kund till de maskiner med problem på. dvs summit 800 -08 och mxz 800 -08 (vet inte om det också gäller renegade 800'an, men tror inte det). Men för att få ut den nya och bättre remmen måste du lämna tillbaka remmen som sitter på skotern till din ÅF, i utbyte får du den nya och bättre remmen.
Snowlabile
25 dec 2007
414
På dootalk snackas det om att dom lägger till nån "shim" distans för att sänka temperaturen på variatorn , vilket gör att remmen håller längre.
Snowlabile
25 dec 2007
414
"-Belts- He said strait up that the 377 belt is a REALLY good band-aid. What happen was they did a early summer production run and everything was perfect. When they went to do there fall production run 2 weeks before, the company that they outsourced the cast mounts/engine cradle ( I can't think of the piece) went into bankruptcy. So they had to send some of BRP's workers over to the plant to try to figure out what to do. What end up happening is some of the cast pieces are out of torrence pushing the engine either inward or outward (I think it is inward, but don't quote me) so instead of the spec being 37mm it was more like 34mm. He said the most he saw one out of spec was 3mm. They have found a new company to do there cast work and they feel very confident they will get it right.
-adjustable motor mounts - It is a thought that is in the air right now. They have not committed to it yet. He said currently there is a little room to move the engine around and if they decided to allow a little more adjustment it would be just that a few more mm of adjustment (2stroker I originally thought he said it was a for sure thing but after hearing him twice after that he said it was a possibility but not in stone.
-Clutching- He acknowledge the excessive heat... he said most of the heat is coming from the misalignment of the primary, but some of it is also do to system balance. The updates will be new primary ramps (they don't even have a number yet), different Helix ( don't quote the numbers I might be off a degree or two) but from what I remember was they where going to a 43/47 helix which is supposed to fix the RPM issue of sled runs perfect in the deep and you jump on the trail and over-revs. The belt/deflection adjuster is going to be updated as well. Also there is going to be new primary rollers."
http://www.dootalk.com/forums/index.php?showtopic=218889
