[video=youtube;NZhky4Owq1w]http://www.youtube.com/watch?v=NZhky4Owq1w[/video]
"Its not a big deal. Make sure you hit the kill switch before engine goes under. Pull it up, remove spark plugs, dump oil in cylinders. MT fuel tank and oil, add new. pull over cylinders while oil is in them. Disconnect electrical connectors and add silicone grease. Dry machine out, then start and run up to operating temperature. Good to go again for round two... Important to do all of the above as SOON as you pull it from the water so that it doesn't start to oxidize. Don't let it sit and dry."
